LycraLout
Regular
Hi there,
This is my first post, so please be gentle. I would like to build myself a cheap(ish) tourer. I have a Ridgeback Flight in my shed which I bought in 2008. It never gets used now as I have got the cycling bug and graduated on to nicer road bikes. My plan is to buy a Surly Long Haul Trucker frame and strip the parts off the Ridgeback and put them onto the Surly. I realise that I'll need the Surly frame designed for 700c wheels.
The Ridgeback has a Sora triple chainset and Sora sprockets, it also has flat bars with STI thumbshifters. I would want to change the bars to new drop bars with appropriate STI shifters, probably also Sora.
Question one is could I use these gears with drop handlebars and STI shifters? Instinct tells me that what method you use to tighten or slacken the cables and change gear shouldn't be a problem, but I'd be interested to know the definitive answer.
Question 2 relates to the bottom bracket. I have removed and serviced the external bearing BBs on my road bikes without any problem, but the Ridgeback BB is not of the same type and it looks like it needs a special type of tool for removal. Could anyone tell me what type of BB a Surly LHT frame would typically use?
Thanks in advance, and if this should more appropriately be in the "Know how" section then please accept my apologies.
Andy
Andy
