I'm planning a St Malo to Nice tour next year and will be using a Ridgeback World Voage touring bike lightly loaded. I'd like to upgrade the standard wheels and tyres to improve performance. Any recommendations would be much appreciated.
For a touring bike, if the wheels are to be trusted that you won't have spokes failure then you need to look at tyres with low rolling resistance, there is where you will gain the best performance per £.
You need to consider though, achieving the extra performance might bring more time fixing punctures. I know what I'd would choose
Maybe looking at your gears and your previous experience with the bike, that might reveal something that will make a positive difference.
Check the tyres though. I've a Specialized 37mm tyre that says 75-100psi on the sideWith wider tyres at correspondingly lower pressures you will also have fewer punctures
I'd usually use 50f/65r in that width, so that tyre isn't comfortable.Depends on the bike. At best, finding a suitable place, removing the luggage, taking the wheel out and changing the tube while removing the cause is annoying.I don't have them often, and when I do they are quickly fixed: just put in a fresh tube, and don't waste time on patching them, and certainly not on the roadside.
