grldtnr
Not sure this the best place, I have an LED trailer board, worked fine when first had it, but since then I changed cars,still a Skoda but a more modern model.
The problem is it's not working properly now, the lamps light up in the wrong fashion, put the turn indicators on the brake & rear lights flash in sequence to the turn indicators, the brake lights work, but then the indicators flash as well, the only function to work properly are the rear tail lights , a conundrum indeed!
I suspect a short somewhere, there is a bare patch of wire, which I temporary taped up , but still happens, being LED, I can't see how to strip the wiring out to check it.
I use it for trailer mounted bike rack ,& when trailing the boat.
any wise scrotes here?
