I've bought a Treadmill to train on when the weather is not too great (like at the moment). The family are also planning on using it. I can either put in the house or garage. My longer term plan is to set up a small gym in the garage e.g. TT for the bike and a weight bench.
I cannot decide on the best place to put the Treadmill. I’ve heard lots of conflicting advice on where the Treadmill can go. Some say it must be temperature controlled, due to moisture etc getting into the electronics and easier to set up in the house. Others say use in the garage and it should be fine. I’ve spoken to the manufacture and shop where I purchased!! Given the Treadmill weighs over 135 kgs I’m a bit loath to drag into the house. If I use in the garage what is the best way to prolong the life of the Treadmill, e.g. heat the garage (it’s a double) until the room has reached a temperature –this could be expensive!!
What is the best type of heating to use?
Any advice much appreciated.
