Trig Points
simon.r
Person
Nottingham
I normally whiz past (all things being relative:rolleyes:) this trig point which isn't far from me, but I'm recovering from man-flu and this morning's ride was a struggle, so I stopped to look at it:
Apparently these are now disappearing http://en.wikipedia.org/wiki/Trig_point#United_Kingdom as digital mapping takes over.
Just thought I'd share^_^
Deleted member 23692
If you're within 10ft of a trig point, your sandwiches taste better
Globalti
Can any surveyor explain the purpose of the slots and the eyes? My guess was always that they provided a stable anchorage for a theodolite, am I right?
ColinJ
Puzzle game procrastinator!
A repeat of an interesting TV series called Map Man|/i] has been showing for a few weeks now. It features Nicholas Crane out and about, talking about old maps and mapping techniques. You can probably catch some of the programmes on iPlayer.
In one programme, Crane took some old surveying equipment to the top of some hills and demonstrated the triangulation technique. It amazed me that they used to start from a base line measured using a metal tape, and all the other measurements were relative to that and calculated by triangulation.
Some trig facts...
1. The survey control network of trig pillars was accurate to 20 metres over the entire length of Great Britain. Today the receivers that make up the OS Net network are coordinated to an accuracy of just 3 mm over the same area.
2. Starting in 1936, 6,500 trig pillars were built for the retriangulation of which around 5,500 are still standing. In total the retriangulation had in excess of 30,000 coordinated points. The modern OS Net network performs the same function with just 110 points.
3. Measuring angles by eye from a trig pillar meant the retriangulation was reliant on good weather – perhaps part of the reason it took until 1962 to complete! Modern GNSS surveying works in all weathers and is available 24 hours a day.
4. Trig pillars are mostly made of cast concrete but a few are built from local stone cemented together.
5. Like an iceberg, there is more of trig pillar below the surface than above it.
Wirral
The middle circular bit screws out with a two pin wrench to expose a mounting thread for survey instrument, brass channels are for tripod legs to enable fine adjustment apparently. This is gospel from my scout master <mumble> years ago. Occasionally a trig point will supposedly coincide with a channel (allegedly, they are always miles away to really know!) but any coastal trig point proves that to be false!
Similar threads
