triple to compact
Brad123
Have been thinking of changing my shifters. My bike is a triple and 8 speed. Can I change the shifter on the chain ring to a double, and just take the granny gear off to make it a double?
Is the spacing between the sprockets the same on the triple and the double?
Or do I have to bye a new chain ring?
ColinJ
Puzzle game procrastinator!
Nobody is forcing you to use the granny ring, so why not just ignore it if you don't need it?
One day though, you will encounter a 20% climb into a headwind when you are knackered and then you will be grateful for it - I certainly was when it happened to me!
Brad123
Brad123
I got the shimano sora 3300 with the thumb shift and don't like them. Have been looking on EBay at shifters and most of them are for double. That's why I asked the question
Hacienda71
Iirc, yes you could change the shifters and make it a double. The limits are set by the limit screws. You can use a triple shifter for a double. But you can't use double shifters to operate a triple.
Adam4868
Swapped my sora shifters( thumb ones) for the newer paddle soda shifters and can't tell you how much better they feel.
