Turbo trainer set up, help!
Rigney93
Hello,
Please tell where I am going wrong setting my bike on my Elite Mag Volare turbo trainer!
CXRAndy
Lincs
Turn the trainer around 180°
The mounting points where its say Elite in red should be attached to the rear wheel spindle. You usually change the skewer to match the Elite mounts
mcshroom
Bionic Subsonic
You need the correct skewer in the rear wheel (it needs to be a turbo specific one to fit the mounts), and then you need to fix the back wheel into the two mounts at the top of the trainer. After that, the sprung roller can be moved up to contact the wheel.
That tyre will also be rather noisy! You'd be better with a slick tyre.
The red bit with elite on clamps the axle of the rear wheel. As others have said you might need a specific skewer that slots into the turbo ?
Vapin' Joe
Formerly known as Smokin Joe
I'm surprised that people have fallen for this.
Next week, which end of the bike does the saddle go?
OP joins the forum at 13.45 today.
OP makes this post at 13.48 today.
Since then nothing. He hasn't been back on to see the solution this major problem
This shouts out TROLL.
