After seating the tyre poorly last night I had the tyre roll off the rim and inner tube explode whilst out riding. This isn't an issue however as I am 99% sure it was user error i.e. my cak handedness.
The issue was, they were brand new tyres, and when repairing the puncture etc... I noticed a part of the bead, well away from the area of the blow out, had two little cracks in the rubber and I could see the aramid fibres in side.
Prob only 3mm long running a cross the bead, barely a mm a cross.
Is this going to be a massive problem later on? The sort of blow out that involves air ambulances or am I being paranoid?
Tyre has mounted back and seems fine tho.
