gillelive
- North West
In terms of tyre pressure the rim on my crosstrail states max of 85, this may sound like a daft question but should I get the tube to the max? I tend to keep it around 80.
Go with the max it says on the tyre or very near to. Will help repel any foreign object from puncturing the tyre
My Vittorio's also max at 145. I run at 140... with my Halfords track pump no problem.![]()
Running the tyres at a low pressure increases grip, makes the ride far more comfortable and stops the bike 'bouncing'' off every bump.
Also on a very rough surface a softer tyre actually has a lower rolling resistance.
Strewth! I'm pumping mine up for theracerun into Whitstable, then...
It all depends upon where you are riding!
Pumping the tyres up hard will decrease the rolling resistance on the road. However if you're riding off-road then you will probably want your tyres as soft as possible (30-35psi).
