steveindenmark
Im looking for a 622x32 tyre which is fast on the tarmac as well as being very tough on gravel.
Any suggestions?
Any suggestions?
That is exactly what 80km of gravel will do to tyres that are not suited to it. If you cannot add anything constructive. Why add anything at all?I'm not sure what "tough on gravel" means, but no tyre is not tough on gravel. Gravel doesn't eat tyres.
That is exactly what 80km of gravel will do to tyres that are not suited to it. If you cannot add anything constructive. Why add anything at all?![]()
Which continental is it.?I've just replaced my front tyre with a Continental 622x32. My LBS were quite enthusiastic about the tyre. It's early days - I've only cycled around 200km on it - but I have not experienced any reduction in speed on tarmac, and it looks like it'd eat gravel for breakfast.
I suspect the OP is referring to cut resistance here. I've got a random pair of old 26" MTB tyres fitted to the bike I use for messing around on gravel and woods tracks on. Both tyres came with secondhand bikes. One is covered in small cuts caused by frequent contact with sharp objects, the other (rear) tyre has survived almost unscathed. The cut-up one is a very ratty looking and fairly worn no-name cheapo job, the one that shrugs off cuts is Trek branded. Neither tyre has suffered a p*ncture in the 500 miles I've ridden since fitting them, but the Trek one seems to be wearing less quickly than the no-name. I expect to change the ratty one in another 500 miles or so, the rear Trek one probably has at least a thousand miles more left in it than the front one at the current wear rate.
I've never ridden a recumbant, so I can't say whether it is more prone to wheelspin that a bicycle or not. However, bicycles don't wheelspin enough for it to make any significant difference to tyre wear.If you're doing a lot of very steep up/down hill runs on loose gravel then I can see a tyre being worn out very quickly.
The more the tyre slips on the surface, the quicker you'll wear it out.
I've worn a tyre out on the back of my recumbent trike in under 1,000 miles just from the amount of wheel slip on steep wet tarmac.
In that case go for a tyre that has a thick amount of rubber making up the tread.
That's the reason I get twice the distance before it's worn out from a Schwalbe Big Apple vs a more sporty type of tyre, roughly 8k-10k miles out of a BA vs around 4k-5k from a Schwalbe Marathon Supreme/Racer/Tryker.
Beg you pardon (don't shout at meNo gravel used by any roads company is made from a substance that produces a sharp enough edge to cut tyre rubber.
but cuts yes, gravel can cause them.No tyre gets abraded to a point of no use by any type of gravel.
Not sure about them: I like the way they ride, but had 2 successive pairs that got lots of cuts plus resulting punctures, after only about 1,000 miles.Schwalbe Land Cruisers?
I've got them on MX Sport and they seem a good balance between speed on tarmac and an ability to cope with the off roading I do..
Plus they're cheap as chips.
