HJ
Cycling in Scotland
- Auld Reekie
Maz said:How fast can a unicycle go? Does anyone know?
Maz said:I guess for a given cadence, wheel diameter is the big factor w.r.t. unicycle speed, like Arch said.
Aah, but then you've got tyre pressure, tread and stuff like that...!Arch said:Strictly speaking, since the cranks are fixed, for a given cadence, surely wheel diameter is the ONLY factor!![]()
Maz said:Aah, but then you've got tyre pressure, tread and stuff like that...!
Thinking about it, you're right!..it's a fixed gear, so for a fixed cadence, the distance travelled must also be fixed. Low tyre pressure would probably bring your cadence down, but here it's assumed to be constant.Arch said:Have you? Those things affect the level of effort you put in, and therefore the gear you're in etc. But on fixed cranks, at a certain cadence and a set wheel size, you're going to get a fixed speed. I suppose if your tyres were actually slippy and you were riding on a slippy surface, the wheel might slip, but I doubt you'd stay on in that situation anyway.
Someone tell me I'm right, I'm starting to doubt myself...
Maz said:Thinking about it, you're right!..it's a fixed gear, so for a fixed cadence, the distance travelled must also be fixed. Low tyre pressure would probably bring your cadence down, but here it's assumed to be constant.
It's me who's losing it...!
