4600 uses the same as the other old 10sp, and the old 10sp mechs also work with any Shimano 8 or 9sp (though the narrower cage can cause rubbing on wider chains).
The one to watch out for is 4700 which is 10sp, but the levers/mechs use the new 11sp standard for cable pull.
