Useful gadget?
downfader
extimus uero philosophus
'ampsheeeer
Gasman said:
Just needs a tweak to the accuracy. . .
I've said it as a joke, never though anyone would be brave enough to ACTUALLY do it.. :ohmy: They flew in every direction too. I'd imagine some blades or feathers like on an arrow would make it more accurate. :laugh:
bauldbairn
Falkirk
Very interesting - now if they had warheads fitted! :laugh:
Remember, there's a lot of fuel splashing about on a bike(the fuel cap / carbs / injectors / fuel filters) and he's firing wayward rockets - brave guy. :ohmy:
bauldbairn
Falkirk
Miquel In De Rain said:
Not really,its held in a tank.
I expect everybody already knew that - its got to come out the TANK to get to the engine. Hence mentioning the "fuel filters", "Carburettors - atomisers", "fuel injectors", "the fuel cap - for filling the TANK" and "Air Filters."
I've yet to drive a bike that didn't have fuel spill over from accidental overfilling at refill time - it runs down the sides of the TANK into the fairings over the cylinderhead / around the gearbox.
Any blowback through the carburettors infects the airfilter with fuel and accumulates in the airbox - which will have a drain hole for the fuel to leak out. The fuel gets to the carbs through pipes/hoses that often leak.
Fuel injectors are fed from the TANK by pipes/hoses that have passed through a fuel filter(mostly found on the outside of the TANK for ease of servicing), these pipes/hoses often leak. I'm not talking excessive amounts - just drips / dribbles / splashes - but enough.
Yes there is indeed fuel around the bike other than IN the TANK, most of it harmless unless exposed to a source of ignition - which a rocket / firework is.
It was just a passing remark - by the way! But a truthful one. Hence the wink. ";)"
bauldbairn
Falkirk
KentMikey said:
Funny i have never seen a motorbike burst into flames and there have been a few clown moves and the tit was wearing hi-viz.
Try "Googleing" - "motorcycle bursts into flames", "motorcycle on fire" - there are hundreds. All self inflicted, all bikes on fire.
