Shimano 11sp (9/10 with appropriate spacers)
SUB 1500g wheelset
RRP £449
Grab a superb bargain - you couldn't buy the constituent parts let alone the assembled wheelset for anything near this price.
Arc ultrawide performance rims are built with quality Sapim spokes onto our Volta EVO range of high engagement hubs.
Our best selling Arc range of rims is designed to be wider to allow a rounder profile tyre for speed, comfort and aerodynamics. The benefit of a wider rim is that the tyre bead hooks are spread further apart, simultaneously rounding out the tyre's profile and increasing the tyre's internal air volume. This allows the use of lower tyre pressures, increasing rider comfort while decreasing rolling resistance. Tubeless ready with our LokR bead gripper profile, for easy installation with or without tubes.
Arc22: Low profile and ultralight. 19mm internal ultrawide rim is what all the big brands are only just releasing as the latest must have product. 645g Front, 850g Rear, 1495g Pair
The Volta EVO is our latest superfast pickup hub designed to be a worldbeater with the best SKF bearings and precision machining. 72 points of engagement with 3x2 double tooth freehub for bombproof reliability and superfast pickup.
Built in the UK with Black Sapim CX-Ray spokes and Sapim nipples, only the best quality components and build will do.
View: https://www.instagram.com/p/BfHEaIMggFx/
SUB 1500g wheelset
RRP £449
