Sam Kennedy
- Newcastle
With my new road bike, I've already managed to rip off a presta valve pin, and bend the pin on the new tube I installed.
Since I bent the pin, I've had a really slow puncture, it takes like 3-4 days for the tyre to go flat.
I was wondering if I should try and bend the pin back straight?
If the leak is taking 3-4 days to let the air out, if I'm actually riding the bike, will my weight (63kg) make the air leak faster? Will I be able to do 50 miles if it's taking days for the tube to leak all it's air?
I just found out I was using my pump wrong, I'm supposed to knock the pump sharply from the valve, not wiggle it off!
I'm a bit hesitant to replace the tube, because these new ones I got were expensive, and would prefer not to use them.
