Very short quill stem
Discussion in 'Wanted' started by Dave5N, 29 May 2008.
  1. Dave5N
    Dave5N Über Member
    I need a really short (80mm or less?) quill stem for my son's bike. It is a bit big and he is very stretched out and finds his neck aches when on the drops for a while. A shorter stem will pull him back and he might actually get off the nose of the saddle!
    Does anyone have such a thing?
    Many thanks
  2. bonj2
    bonj2 Guest
    why don't you get a proper headset dave!
  3. OP
    Dave5N
    Dave5N Über Member
    Because the bike has a threaded headset.
  4. bonj2
    bonj2 Guest
    get a proper i.e. threadless headset. Take the old fashioned headset off. Put the proper headset on. (Or get a bike shop to do it).
    Then you'll be able to fit a proper stem on.
  5. Amanda P
    Amanda P Veteran
    Nothing wrong with threaded headsets and quill stems.
    I have a 70mm Cinelli one - any good? Yours for, say £5 via PayPal and in the post tomorrow.
  6. bonj2
    bonj2 Guest
    Well, there is - if nothing else that there's not as good a range of stems for them!
    I had a bike with a quill stem and it kept coming loose, so i don't trust them.
  7. Amanda P
    Amanda P Veteran
    Fine. You carry on with your lumpy, heavy, inelegant threadless setups, Bonj.
    Meanwhile, Dave5N knows what he wants and it's a quill stem. Much as you may disaprove, fitting a shorter one is a much cheaper and more appropriate solution to his problem than buying a whole bunch of new parts just because you don't like the design of the old ones.
  8. bonj2
    bonj2 Guest
    more be luck than judgemenet.
  9. OP
    Dave5N
    Dave5N Über Member
    Bonj, you reveal more of your ignorance with each post you make.
    Uncle Phil, many thanks. I'll get the tape measure out and get back to you.
  10. bonj2
    bonj2 Guest
    the world's moved on now dave.
  11. Bonj, be quiet. Dave doesn't want a threadless headset, he wants a quill stem. He already knows about threadless headsets and doesn't need you banging on the inside of his computer screen shouting about them.
  12. Yorkshireman
    Yorkshireman New Member
    d'you mean? ;).
  13. bonj2
    bonj2 Guest
    well, it's adjustable, but i'll let you off.
  14. Yorkshireman
    Gee! Thanks bonj :tongue: It replaces this one
    which was a little bit too high (but only cost a couple of quid) and looked a bit gormless. The original conversion looked like this
    and I thought that looked even worse, though the bars seemed more or less where I wanted them. I found that SJS do a spacer that just 'filled the gap'. I suppose that I could have fitted one of these
    but I wanted black and an open-face clamp (and anyway that cost more than the bits I finished up with anyway). So, I reckon that I have the best (or worst?) of both quill and ahead :smile:.
    Dismiss Notice
