We are in need of organisers to oversee the smooth running of a section. In my mind this does not outrule you to actually riding in the event. You will need a reasonable knowledge of the region you are looking after and will need to map the sections as Peanut has done for the South 2 section.
It will be your responsibility to ensure you have the riders assigned to each section, they are aware of ETA's and are prepared plus that a support vehicle is sourced (can be an LBS helping out or a mate in a car with a track pump, umbrella and a blanket).
A ROUGH Guide to region start and end points is below (final handover points will be decided from a south - north basis), if you would like to get involved please copy/paste the list and add your name to the region.
South 1 - Lands End - Sandford =
South 2 - Sandford - Gloucester = Peanut
South 3 - Gloucester - Stoke on Trent =
Mid 1 - Stoke on Trent - Preston =
Mid 2 - Preston - Penrith = Garz
Mid 3 - Penrith - Moffat =
North 1 - Moffat - Cowdenbeath=
North 2 - Cowdenbeath - Kingussie =
North 3 - Kingussie - Dornoch=
Glory run - Dornoch - John O' Groats =
Thanks for your help.
