I've got a Wahoo Elemnt bike computer. Lately it's started switching it's self off mid ride. Yesterday I set off pressed start ride and just got n/a in every field. Trouble is the stupid thing is so small I can't read the smaller writing on it without my glasses and I didn't have them with me. I tried randomly pressing the buttons but with no joy. Has anyone had similar, any ideas how to sort it out or should I just hit it with a brick.
Should have known better than to buy a computer from a company that can't spell!!
It's difficult to understand what the problem is with that description.
First of all, to see better, you can reduce the number of fields on each page (or make your own) in the app. That will make the letters bigger.
Alternatively, the up/down buttons will zoom in and out giving the same effect.
My Elemnt behaved badly once, when I set off not knowing it was mid update. Other than that it only switched itself off when out of juice.
If, for whatever reason, it didn't start to record the ride it does have an automatic "off" function, again set in the app. Was it recording on the other days when it switched itself off?
Is the unit visible in the app? Sometimes the unit needs to be resynced with the app.
You don't say what fields were blank? If external sensors it may be necessary to resync them with the unit via the app (I don't use external sensors).
Failing all that, a factory reset will clear the unit (not the app) and you can start from scratch. The only possible impact (I think) is that any routes on the unit (manually transferred) and any rides (FIT files) not transferred to the app will be lost. Routes, previous rides on the app will not be affected.
A factory reset is accessed through the left hand button.
I don't know how to say this without sounding like a d*ick, but randomly pressing buttons rarely helps. Maybe an idea to play around with app and unit at home until you feel a bit more comfortable.
Failing all that, you can google as accurate a description as you can or Wahoo Elemnt Users Group.
And please don't bash your Elemnt with a rock!
They're discontinued and in my experience are a great bit of kit.
