Wall Rack for Garage?
davdandy
Lowton/Leigh
I have a similar one from Halfords i bought last year.Just make sure you have a sturdy wall,brick and not breeze block and use either three inch screws or bolts.Other than that very secure.
davdandy
Lowton/Leigh
You may get away using breeze block for one bike but using two bikes takes the weight over to the edge and would most likely pull out of the wall.Either use a solid wall or even put a plywood board on the breeze wall first then hand the rack on that to spread the load.
Sharky
Kent
I've got two similar, but without the hinge to make them fold.
Have had a couple of crashes in the middle of the night when the screws have come out, but once you've sorted out the correct fitting, they are very good.
Measure the distance you need from the ceiling for the bike with the longest seat post, otherwise you get lots of practice putting them up and taking them down!
Keith
bigup
bigup
thanks guys, i fitted it in the end, seems strong
but wasn't sure i fi was supposed to drill into the mortar or the brick itself
i drilled into the brick using the supplied screws and raw plugs
doog
You could always use those beams as well. They look strong enough to take some decent hooks.
This is my very basic set up having attempted to hang from the wall without success.
ATTACH]
