Will1985 said:
I'm currently looking to put a cable stop on the downtube as well - googling came up with 2 neat ideas - blind rivet a boss on (LBS job), or simply araldite/epoxy glue a new cable stop from Campag onto the frame.
Hi Will, I've had some new info from acouple of very hepful posters - it might help us?
I'm told they're called "RIVNUTS" looks like a clever idea but I dont fancy drilling the frame. Must admit I hadn't considered araldite etc - mind you, I cant even stick my fingers together with superglue so I'm not hopeful
It seems that SJS do a little gizmo for £4.99 its essentially a clamp with the bosses already fitted, you just screw on the cable stops. I trawled every LBS for miles and nobody had any old shifters - I was lucky enough to win some Shimano 600's for £3.50 last night on E Bay - Just hope the cable stops fit. I hadnt considered the need for "in line" cable adjusters either I'll send you the link if you need it?
