Washing machine woes
johnnyb47
Wales
Hi,
I went to visit my dad today and he started messing around with his washing machine cleaning out the pump filter.
He was very belts and braces about it,in that it should be done every few weeks. He showed me the gunked up filter and it did look pretty disgusting to say the least.
I ashamably admitted to him I've never cleaned mine in the several years I've had it and after a few words he convinced me that I should do mine.
After a seventy mile drive home I looked at my very sad looking washing machine and decided to tackle the job of cleaning the filter.
I prized the white cover off and then undone the cap but the filter refused to come out.
Being the stone age knuckle dragging lump I am , I put a tad to much force in trying to get the filter out and cap detached it self from the filter.
I managed to get it reattached and then after a few more failed attempts I gave up before I completed destroyed it.
I tightened it up it and put it on a quick wash cycle to ensure it was ok.
To my horror the water started flowing out of the screw in cap all over the kitchen floor.
Not the most practical and certainly the most ham fisted person I am I resigned myself that the once working washing machine was no more.
Sitting down in a strop contemplating the prospect of buying a new machine my ex brother in popped round for a brew.
Now he's the total opposite to me.
For a start he's got more than 2 brain cells unlike me and a lot less ham fisted.
So between the pair of us we dragged the washing machine outside into the garden and lay it on it back with the intentation of taking it apart (well what have I got to lose)
I went to undo the threaded cap again to show him that it's stuck and subsequently now leaking ,but this time it just came out with on issues what so ever.
Strangely enough this particular servis model didn't have a filter.
You could just see the impeller of the pump.
The rubber seal looked in great shape too !!
I did however find 57 pence worth of coins inside as well as a safety pin and a hair slide which must of been from my ex wife (and she run off with the milkman well over 7 years ago)
Between us we slowly fished out all the shrapnel ,cleaned it up.
I wasn't keen on dragging it back into the kitchen again just incase it leaked so we filled it up with a watering can in the back garden,hooked it up to the extension cable and switched it on.
Success no more leaks from the filter pump .I tried it again and again and all was good.
We dragged it back in,cleaned it up ( I didn't realise it was brilliant white 🤣) plumbed it in and now works perfectly.
I suppose the moral of the story is , don't listen to your dad's advice, make sure you've got more than a couple brain cells before attempting to fix anything and always have a good friend who knows what there doing with such things.
In hindsight I think one of the coins must of somehow lodged itself in the screw out housing preventing me from removing the gubbins and when I re tightened it the hair clip or something got in between the rubber seal.
On a positive side I've now got some loose change for a cuppa tea at work this week 🤣
What a complete Wally 🤣
classic33
Leg End Member
You certain there shouldn't be a filter in place, if even to stop only the larger bits getting caught/stuck in the outlet hose?
You stopped, had a thought about it, and now it working again. As for how you didn't know it was white...
And yer in profit as well.
Widnes
There is always the option of looking in the manual
they are often available online
I recently checked ours and the manual said
well - I have no idea - I just pulled and pushed a few bits and it came off
I am all for manual - but first call "for a real man" is trial and error - otherwise known as instinct
Unless it is electronic and complex - THEN the manual is needed
Unless you are a woman - or unencumbered by centuries of expectation and testosterone - and possibly common sense
Which reminds me
when I was a senior programmer in charge of a team of 25 programmers
the ones I trusted most to just get a job done and tested and not have problems
were the 3 women!!!
johnnyb47
johnnyb47
Wales
It is a bit of a strange one that theres no filter.
Come to think of it we noticed there was a couple of small screws missing too from the filter housing.
We did however buy this washing machine from a large store that sold seconds.
Ex display stuff.
Its now got me wondering if someone has had it apart before we bought it
oxoman
My Miele washer doesn't have a filter in the conventional way of thinking, it has like a trap that stops solids. For us that is usually small screws and nuts, anything else we normally find in the door seal. So it may not be a filter with holes etc.
annedonnelly
Girl from the North Country
Canonbie
Does no one empty their pockets before washing clothes? The trap thing in my Miele just gets a bit grimy not full of junk. Unscrew slightly & allow to drain into a tray underneath, then unscrew fully, remove & give it a good clean. Make sure you screw it back in straight when you put it back.
MontyVeda
Word of warning here... some dodgy websites lurk at the top of the results for service manuals so double check you're on the manufacturers website first, otherwise you might download a batch of malware with the manual (don't ask me how i know this)
Ours has a trap - it's called a filter, but there isn't mesh, it catches anything larger like coins, which used to be the main thing that returns an error code (computerised machine). Very obvious when opening it up, and I could see a couple of coins.
