Wattbike / WELLGO E148 PEDALS Compatible with SPD SL?
Loch side.
I can't comment on the red Look look-alike plastic cleats but the SPD-style cleats I know very well. Wellgo uses a cleat called a 98A. Those are the ones in the photo. They look like SPD cleats but they're not perfectly compatible and work far better on Wellgo pedals than Shimano.
However, if you are on a stationary bike, it doesn't really matter. The incompatibility only shows up with sticky/grindy unclip. Since there's no risk of falling off, they will be fine.
The read cleats look like copies of the first Look cleats.I have no idea what they are compatible with. Look at the Wellgo website.
Loch side.
@Yellow Saddle
Thank you for getting back to me,
When you say SPD, do you mean SPD SL?
I don't fully understand your answer.
Thanks
Yeah, I was a bit all over the place.
The little black cleats are SPD and they fit in the underside of the pedals in the picture. The red cleats are lookalikes of Look or perhaps even SPD SL. I have no experience of those. However, Wellgo tries to be as compatible as can be without breaking patents. I bet those will be workable.
You ask how do you use SPD SL with a Wattbike. You fit SPD SL pedals.
I'm not quite sure what the problem is. Do you have existing SPD SL shoes and pedals and want do get/get on a Wattbike?
T
TerryTibbs10
@Yellow Saddle
There is a wattbike in my gym.
I realise that I could swap the existing Wellgo pedals for Shimano SPD SL pedals but that would be a bit of a hassle and if I left them there the vast majority of other people could not use them.
I have SPD SL shoes and the existing pedals on the wattbike have cages on the other side (which I am hoping is SPD SL underneath, i.e I simply remove the cages and put them back on after my work out)
Referring to your second sentence in your last answer are you basically saying that with that Wellgo pedal I can use an SPD SL cleat?
Loch side.
In other words, the Wattbike in your gym doesn't have the pedals in the picture, instead it has flat pedals (with clips and straps) on the one side and something else, possibly SLs on the other side.
Removing the cages each time is no good. You won't wanna do that. Why not just see if your SLs fit? I think they will.
T
TerryTibbs10
@Yellow Saddle
No, I am fairly certain that the pedals in the photograph are the ones on the bike and the cages fit into the unknown fitting... see this photograph (not from my gym)
the snail
Chippenham
@Yellow Saddle
I don't think so, but you could fit look cleats to your spd sl shoes, the mounting holes in your shoes should fit either
Milkfloat
An Peanut
Midlands
By default the Wattbikes have SPD (not SPD-SL) and the horrible Wellgo fitting on the other side that seems to not really work with anything despite claiming to be Look Keo compatible. You then have the orange plate with a cage and toe straps that clip into the Keo side.
My suggestion is to get a second pair of shoes with MTB style SPD cleats.
T
TerryTibbs10
@Milkfloat Thank you, that answers my question.
You'd think that given that Wattbike is designed for fairly serious trainers, they would fit SPD SL as standard not something designed for mountain bikes / commuters.
Except not everyone rides clipless even 'serious' cyclists, especially if it's in a public gym
Milkfloat
An Peanut
Midlands
The problem is that Shimano won't license their design for SPD-SL to anyone, hence you don't get any 3rd party pedals. Look Keo is still a pretty popular choice though. There is no way to support all designs as you would need, speedplay, spd, spd-sl, look, time etc.
Loch side.
I agree, with one caveat. Get the Wellgo 98A cleats. They will work perfectly with those pedals whereas the Shimano cleat won't.
