Weird tyre pressure
Andy_G
Staines
A couple of days ago i went for a ride(about 60 miles), pressure was 120psi so all is well, a few hours after i got home i went to check the psi and the rear tyre was soft(not fully deflated).
The screw was tight on the valve so i cant be that, the only other thing is about 40 miles in i was behind a car and i hit a pothole pretty hard with the back wheel.
Any ideas
Andrew_Culture
Internet Marketing bod
How much pressure had you lost? How old is the tube?
ianrauk
Tattooed Beat Messiah
Rides Ti2
Yup, something in there.
Take the tyre off and run a babywipe or cleaning cloth inside of the tyre. It will snag if something is stuck in there.
Davidc
Somerset UK
If what RP says isn't the cause (odds on it is) then look at the valve. Contamination (piece of grit etc.) or failure of the rubber in the works could be the issue.
If it is they're swappable. (I have a little plastic container with the business bit from old discarded tubes in it, and sometimes need one).
A
Andy_G
Staines
I tried that first and not a single bubble, the only thing I thought of was when I hit the hole maybe somehow it forced some air out somewhere
I like Skol
A Minging Manc...
Definitely not this!
Dodgy valve
Maybe this, If you can't find any bubbles in the bucket of water (including from the valve) when you have pumped the tube as hard as you dare then it could well be the valve is passing air at high pressures so your tyre deflates to a certain point and then stays there. I always add a tiny spot of washing liquid to the water (as I do this test in the kitchen sink it is always close at hand :laugh:) as I find this breaks the waters surface tension so you get a better stream of bubbles rather than a larger one that clings to the tube and may be missed if the leak is really slow.
e-rider
Banned member
South West
some tubes have removeable valve cores such as Continental tubes - these are often not screwed in tight in the factory so this could be leaking. I always check mine before using. However, if you have non-removeable core tubes then this wont be your problem!!!
Any ideas
Plenty of p'tures (maybe the pinch from hitting that pothole) can cause a tiny hole/s in the tube which is only open when the tyre is at high pressure and when the pressure drops it closes and the tyre onlly goes down slowly thereafter.
Davidc
Somerset UK
I've met this, and on a couple of occasions have been unable to find the hole at all, so have replaced the tube.
There's a limit to how much time it's worth spending hunting for a problem in a tube which only costs £3 or £4 to replace! If the tube does it again my view is that it needs to be scrapped.
