jonesy
asterix said:...
I'm sure I read a report once that pollution was often worse in rural areas downwind of London than in the capital itself. Depends on the type of pollution no doubt.
Yes. The distinction is between primary pollutants, those that come directly out of the exhaust like soot particles, carbon monoxide and NO; and secondary pollutants which form from primary pollutants as they react in the atmosphere. NO2 forms relatively quickly from NO, so concentrations are higher in urban areas; and generally still a greater problem near a busy road than away from it. However, with Ozone the situation is reversed, as not only does it take a while to form, through photochemical reactions (which is why it is worse on sunny days) but it reacts with NO, so is actually destroyed by fresh vehicle emissions. As a result, ozone is usually at its highest in rural areas and very low at the side of a busy road. For this reason the first network of ozone monitors was set up in rural areas, as that was where the highest concentrations were to be found, whereas monitoring for other pollutants is focused on urban areas.
