What bike mounted pump but....
Right, my OH wants a bike mounted pump for a road bike but there is a major catch... It must meet these requirements and it is the first requirement that is my problem!
  • Not be a screw on one, but have a head like the ones on a track pump where you turn a lever - this could be referred to as a thumb lock lever if i go by the description of the Topeak Joe Blow Sport II that we have.
  • Must manage high pressures for road bike, so ideally 110 psi minimum
  • Both presto and schrader valves (so it does his mtb as well)
  • Must be able to attach to the frame somehow
  • Have a guage
Does anyone know of one?
Mo1959
Not sure about this? Says mounting bracket so I presume frame fit.
http://www.chainreactioncycles.com/...gclid=CLeo38mM9cECFY_MtAoddhMASw&gclsrc=aw.ds
Yorkshire
Mine ticks all those boxes APART FROM having a gauge. Topeak do one with a gauge and they have a clever head which you don't have to manually swap for Schrader or Presta.
SatNavSaysStraightOn
Changed hemispheres!
I have 2 of these http://www.wiggle.co.uk/lezyne-pressure-drive-mini-abs-pump-small/
i know it fails with the lever - but it has a button you press which then stops air coming out - so kind of does the same job. Also fits on t he bike handily under a bottle cage mount.
Fails at the primary requirement.. It is also what I have, though not the mini version . He doesn't like it and for some reason when he uses it he seems to either bend the core of unscrew it, don't ask how I have no idea!
arch684
topeak mini morph with gauge from wiggle £28
compo
Harlow
I have an Aldi Bikemate mini pump. Twin head, thumb lever, built in guage and comes with a bracket that fixes under a bottle cage. It also has a little switch thing that changes between high pressure or high volume. I know it pumps up to 90psi but more than that I have no idea.
I never use it as I don't like mini pumps, so if you want it for hubby I can soon stick it in the post to you. Be a swap for the stem you kindly gave me a while back!
coffeejo
Ælfrēd
West Somerset
I've got two of the Topeak "morph" pumps and can easily reach 100PSI and 120PSI with a bit of effort. The guages are accurate though obviously not as easy to read as on the track pump.
That would be fantastic... I'll send you a pm...
Soltydog
near Hornsea
I have the mini morph without a gauge & have had to use it a few times. its not bad at all, a bit like a mini track pump. My only gripe is that it mounts to the frame with cable ties & tends to move a little causing scratches to frame. A pump that fastens via bottle cage mounts would be better for me :thumbsup:
