What bike mounted pump
phil-b
west wales
After a house move I have lost my trusty bike pump.
It was bike mounted but acted like a track pump. It had a flip out foot rest to hold it down and then had a flexible tube with an inline pressure meter that connected to the tire and would reach any pressure required with relatively ease. I would buy the same again but I can not remember the make and model. It was quite a few years old so maybe there is something even better now.
What should I replace it with?
jayonabike
Powered by caffeine & whisky
Hertfordshire
wisdom
Blackpool
Depends what your requirements are really(other than blowing tyres up)
I have a topeak race rocket for on the bike use.It is also small enough to fit in a jersey pocket.It will certainly reach pressures to get you home or carry on.Never had a problem at all with mine
phil-b
phil-b
west wales
I will have a look at those suggestions.
I guess the morph was great as an all rounder but maybe slightly large as a pump to be carried. but if I get a mini pump I will have to buy something larger for use at home.
cyberknight
Many of the pocket pumps can get to 100 psi or so but your arms are liable to look like popeye before you get there , i have the road morph and its a fantastic bit of kit .It depends on whether your after a get me home pump or something that you can pump and forget , on the weekender i have the pocket rocket and it will get the tyre good enough to get home but i would need to top it up from a track pump at home .
Doyleyburger
NCE West Wales
I had a look at one of these in the shop it is very small I wonder if it is tough to use?
deflated my rear tyre last night so I could test the little pump out. Performed very well !
Pumped up to approx 95psi with no trouble at all and a lot more to give. Then topped it up with the track pump of course
