Fastpedaller
- Norfolk
Here's mine from yesterday. At my Daughters, I'd fitted a new door to the bathroom and set about fitting the door handles and latch. I fitted the strike plate to the doorframe and placed some masking tape on the inside of the door, marking a line 'about central' from the strike plate to the centre of the hole where the spindle is intended to fit. I drilled into the edge of the door and then attacked it with the chisel. Several trial - fittings later I had the latch in place. I checked the alignment of the latch to the striker by closing the door.
Oops! I was trapped. My Wife and Daughter were in the garden, so I opened the window and told them what I'd done. Much hilarity
, but how do we get you out?
A ball of string was thrown up to my window with one end held at ground level. Thankfull that I'd marked the centre for the spindle, I asked them to get the 14mm drill bit from just outside my door, along with the cordless drill, and the square spindle for the latch. These were put into a carrier bag attached to the string, and I lifted the escape kit up to my window, drilled the hole in the door and was able to insert the square spindle and turn it to effect an escape. Much easier than Colditz or a jailbreak
, but how do we get you out?A ball of string was thrown up to my window with one end held at ground level. Thankfull that I'd marked the centre for the spindle, I asked them to get the 14mm drill bit from just outside my door, along with the cordless drill, and the square spindle for the latch. These were put into a carrier bag attached to the string, and I lifted the escape kit up to my window, drilled the hole in the door and was able to insert the square spindle and turn it to effect an escape. Much easier than Colditz or a jailbreak
