What Device?
Alex321
South Wales
I agree it's going to be a bulkier solution than a dedicated device and might be more of a lash-up but could be a viable option for some.
Where "some" is a very limited number of people.
Basically, only those who can't afford a dedicated unit, or whose usage is so limited that it doesn't justify it.
I've used both, and I suspect most of those responding to you have also used both. And there really is no comparison. I would never go back to using my phone unless I really had no choice.
Dogtrousers
Lefty tighty. Get it righty.
I disagree with this for five reasons:
  • The choice of cycling specific navigation apps is similar on a phone as a bespoke device.
  • Phone screens are not easier to read than a purpose designed GPS unit
  • In the event of a fall a phone screen is more likely to break
  • Battery life is very poor in this situation especially if using an older second-hand phone
  • Who wants to stop to recharge a phone? Riding with a power pack attached to the phone is unreliable.
I'd add a 6th. You want your phone for other reasons. For general communications and some people rely on them for payments and other stuff too. Using it as a GPS puts it at risk of damage or just running out of juice. Sure, use the phone as a backup if your GPS goes kaput.
Dadam
SW Leeds
Which is why, if you read my original point, I was suggesting a second dedicated phone for the purpose.
YMFB
I use a Garmin 1030 + and varia rear light/radar with Wahoo cadence sensors on two different bikes. Each bike has its own profile mainly because the roadie has Ultegra di2 and I like knowing which gear I’m in and I have different screen setups for each bike.
i started with a Wahoo head unit but found it confusing and the map display woeful in comparison. I suspect they are similar now, but I use Garmin on my motorcycle so have become biased in that direction. BMW & Ducati have their own built in sat nav’s, both of which I have tried but gave up on and retrofitted the Garmin XT 2.
There is a lot of talk on motorcycle forums of people moving over to the cheap mainly Chinese units that are more like a modern cars units with Apple CarPlay, Waze and other programmes built in.
like choosing tyres you have to make your own decision, the biggest in my opinion is to have a head unit and save your phone For comms.
Webbo2
One of these, make is Magene if you can see it. Fits on hub so better than magnetic job on spoke etc. These also "double" up as a cadence sensor so I have one on my non drive crank as well. Can get on AliExpress for less than £10 and work great.
I got one of these £7:95 with free postage. Took a week to arrive fitted in 30 sec and on first ride no speed fluctuation.
Cheers 🍷for the advice Binky.
Mike_P
Harrogate
I found a Wahoo Elemnt Bolt v1 confusing when using it with a rear Varia and trying to follow an uploaded route as you get the same warning for going off route as for a rear approaching vehicle. Bought a Garmin 530 and whist that is clear in those respects its user interface must be one of the most confusing there is.
