Interesting story with no conclusion (Yet)
So, my bike is a Team boardman 2014 CX - I've had it for two years and It's only recently after swapping my front disc rotor I noticed something "Quirky" about this bike.
The front fork, FYI, is a Rigid XC Disc design made from full carbon (except the odd alloy insert)
I upgraded my front Rotor from The stock Avid G2 cleansweep to a two piece Shimano Ice tech rotor; after doing so I had noticed the rotor Would Not Turn when on the bike, this was because the 6 Rotor bolts that mount to the hub were catching on the bottom leg of the fork (The leg that goes directly to the lower caliper mount bolt)
This annoyed me, but I got clearance thanks to a metal file and some minor tinkering.
Some time later, This problem bugged me as it persisted at the back of my mind, having about <1mm of clearance down there. I had purchased protective stickers and even resorted to marking the rotor heads with a paint so I could see if it ever was catching. This worked fine.
But I did not want to write-off my fork before the warranty ran out this upcoming December, so, i refunded the rotor and went back to Stock Avid!
.. This did not cure the issue, infact! it made it worse.
After mounting the *ORIGINAL* front disc with the *ORIGINAL* 6 mounting bolts.. It was catching! Imagine that?
Now, I have yet again gained clearance by swapping rotor bolts to a smaller type with "Filed" heads.
You can see from the pictures how close the gap is. - Also, if you will note that my protective sticker was "ripped" up a little from when the original bolts went through them, you can see a minor indentation in the fork leg, that's just where the paint was chewed away, beyond that ridge is carbon fiber.
This is about 0.5 < MM of clearance that you see on the photos.
I've tried installing washers on the axle but it simply pushes the caliper too far outboard and the rotor catches on it the caliper, even with Hilariously skinny washers.
I am all out of ideas now, I tried contacting boardman but they only advised me to take it into a LBS.
I don't think an LBS would be able to solve this issue however. What are your thoughts/ideas?
(Yes, this was a halfords bike, but I did all the building and assembling myself)
Final Note: The Rotor Bolts Do Not Catch, there is still a 0.5MM < Clearance, but is this safe?
