What watt fluorescent tube do I need?
PeteXXX
Hamtun
I need a new 1260 x 29 fluorescent tube for one half of my kitchen (15' x 12' total size)
What wattage do I need for an average amount of light?
I can get 6w 8w 14w 18w 21w 28w 36w & 58w warm white or cool light. Dimmable is not necessary.
And is it wise to transport it 3 miles on a bike?
:smile:
presta
It really needs to be about the same power as the one you're replacing unless you're going to change the ballast choke as well. When I tried to break up an old one before putting it in the wheelie bin it seemed nigh on indestructible.
NickNick
iirc if its one of the ones with a starter in it (a plastic cylinder that slots into the light fitting somewhere, can post pic if need be) they cover a range of wattages, e.g. 4-80W, 4-65W, 4-22W... so you want to make sure its compatible. You best bet as Presta said, is to match the wattage to the bulb you are replacing. I would definitely go for a warm white, its a colour much closer to incandescent bulbs, the cold whites are way too clinical for my liking.
PeteXXX
PeteXXX
Hamtun
Thanks for the input folks.
This is the thingie. No idea re the wattage of the dead one as the information has worn away with age.
:smile:
PeteXXX
PeteXXX
Hamtun
Yep, it's the tube I need. Just posted the pic to see if it would help determine which one I want.
PeteXXX
PeteXXX
Hamtun
[QUOTE 4979762, member: 9609"]all four foot tubes are 36 watts, you won't be able to buy any other wattage for a four foot florescent tube
How do you know it is the tube and not the starter ?[/QUOTE]
The tube is black instead at one end.
classic33
Leg End Member
There a health hazard if you break them, hope you had the full hazmat suit on.
presta
I did know that they contain mercury, but at the time I think my mind was on getting the lid of the wheelie bin shut.
