Where do I split my chain
andsaw
My chain has one of those chain pins that you snap off once inserted, do you remove that pin or should you split the chain at a different point and leave the chain pin in place so I can fit a missing link.
pawl
Don't do it in the kitchen you will get chain grease all over the floor.
I suspect that you are referring to a Shimano chain,if so i am not sure a quick link will fit.Some one with more knowledge will be along to advise.
U
User33236
Why do you want to split your chain?
The Shimano joining link looks different to all other link in the chain. I would suggest if you do need to spilt your chain then do so at that point and use a quick link to re-join to make future disconnects easier
andsaw
andsaw
I use chain wax that you heat up so i need the link to rejoin, I know the shimano link is different as its just a solid barrel but you can't reuse them and was asking as I understand that when a shimano pin is inserted it expand the hole and can cause problems when you use a missing link in the same hole and you should rejoin in a different place and leave the shimano pin in place.
