rosscbrown
I have a a Kryptonite lock which is fantastic but it takes up all the room in the front triangle. As a result I've got nowhere to attach a bottle cage. Does anyone have a creative mounting solution that will keep the lock largely out of the way?
The Kryptonite bracket is at least 30mm larger than it needs to be - is there an "after-market" bracket is a bit smaller?
I know You can mount the lock on the seat post but I don't ride with it very high so that's not an option. Also the rear rack I use is seat mounted, so while I *could* mount it on that, I often ride about without the rack attached.
