Which bike???
g_campbell1983
LURGAN
Hi Folks,
Complete newbie here so need some proper advice. I havent owned a bike in id say roughly 23 years (I would have been 8 at the time).
Anyway looking to get myself a bike, mostly to get fit and loose weight, currently tipping the scales at a mere 20st. The bike when purchased will be used every day for a short journey to the train station along the man road. We live very close to a long cycle track around some lakes so id imagine it will be on there quite often and also spend some time on the roads
I was planning on going to Halfords as I will be purchasing the bike and whatever else I need through the cycle to work scheme. Can some of you good folk give me some advice on what type of bike to buy, models ect and also any kit I am likely to need??
Many thanks in advance
I'd look at a flat bar hybrid bike from the Boardman range...without suspension...which one depends on budget
Other kit:
A good lock, stations are dens of thieves for bikes! Something like a Kryptonite Fahgettaboutit (£70 odd) + a cable for the front wheel too
A helmet if you want to wear one (it's not compulsory)
A pair of mitts/gloves
A buff
Some glasses to keep the bugs away
Inner tubes, tyre levers, multi tool
A bottle cage and bottle if planning longer rides (not needed for 2 miles)
Padded shorts (you might want these from the off as a newbie), wear under 'normal' clothes of preferred (Maybe a tub of sudocreme as your nether regions will suffer to begin with, sorry)
Some sort of jacket with reflective bits (hi viz optional)
Lights, front and rear (Cateye are a good make for 'be seen' lights, if pitch black you'll need better lights to see)
Chain lube
That lot should get you started :smile:
Insurance for the bike through home insurance especially if buying on C2W
