gaz
Cycle Camera TV
- South Croydon
One light claims to output more than twice as many lumens as the other, but which is which?
These are rear lights :PWorried that Gaz is using red lights
Right seems a little brighter from the first pic![]()
The light which claims to be brighter has the tighter beam angle (first of the wall shots).What lights are they and are the beam angles very different? The 2nd shot of the wall looks much bigger coverage, although it's hard to judge brightness from photos![]()
The other one has a much wider spread for several reasons, one being a diffuser lens.
The two wall shots are taken seconds apart from the same location and with the same exposure, shutter speed and iso. Although I wasn't using a tripod, hence the slightly different line up of the shot.
The problem is we're thinking in lumen where actually we need to think in lux of the apparent light surface. A friend of mine is looking into making his own rear light & found that the typical car rear light is something like 1000 lumen, HI rear lights are nearer 2500-4000 lumen & brake lights are typically 10-20% higher than the HI rear. Those very high lumen figures are the reason you can see car rear lights at large distances. However that's only half the story. Because of the large surface area they are no where near as intense at close range.you can see that in the facing shot too, its centre (lets call it) white area is more compact than the right side one too.
more general blather
I think light intensity gets to a point where extra is just unneccesary, you can see & be seen clearly at 'x' lumens; as long as mounting angle etc is right; but manufacturers have to bring out new products to stay in the users perception and those new products have to be sold. 'Look at how bright this one' is tends to be one of the faux USP that they use to persuade us to part with our cash.
Is there any legallity about how bright a bike light can be? I have had people flash me before when I have had my light on full (when I first got it I had it on full on the roads).
I know it is polite to turn down the light when you see a car coming but what is the legality on the actual brightness? My light claims to be 1800 LM (doubt that) and there are people on here with much brighter.
Nope. one of them is c&b seen rear light. I doubt it is what it claims.Which lights have you there Gaz - I assume one is a magicshine ?
Got myself two c&b seen jobbies now - OMFG !
