Which pannier??
luckyfox
She's the cats pajamas
County Durham
I'm looking to get a pannier set for my raleigh, first timer so any advice welcome.
Looking on Amazon, ideally a good waterproof set.
subaqua
What’s the point
Leytonstone
I have
2 no altura Urban and they swallow a huge amount of kit for commuting - set of clothes and my safety equipment, laptop I pad, locks and some tools.
1 altura morph rucksack pannier thing now I don't need to carry as much with me.
It would be useful to know how much you want to spend and how much you want to carry...
I personally love the Ortlieb Classic panniers, but they are a long term investment. I can say for definite that they are 100% waterproof having survived the worst that Scandinavia, Scotland and Wales (not to mention Ireland) can through at them.
they come in 2 sizes and various options. The sizes are marked 'front' and 'rear'.... don't let that fool you into thinking that is where they have to go. I commute with the 'front' panniers on my rear rack. I tour with the rear panniers on my rear rack....
Gez73
Altura dry line for me. 56 litres combined and very waterproof as far I can tell. Not small and only used once a week to be honest but they do hold a lot of stuff and I can get my work clothes in one and a weeks worth of lunch stuff in the other. Very much depends on requirements and budget. I also use a rack bag for daily use too. Gez
  • Like
Reactions: _aD
wintergreen
Sunny Manchester
Ortlieb for me. Plenty big enough for everything I need to take camping and waterproof. They are a little pricey but its worth the investment. They are well made and stand up to all kinds of abuse.
As SNSSO mentioned the front rollers can be used either on the front or the back so depending on what size you need on the day they are interchangeable.
_aD
Do not touch suspicious objects
There's a smaller set of Drylines that are 32l - ideal for front racks or smaller loads. Had my Drylines for years, use them most days and on dozens of rides in very, very wet weather for many hours on end. The inside of them tends to be the only dry bit of the bike left! The external material is tough and fixings secure.
n.b. they do get wet inside when the bottoms get dipped in Accidental Fords.
summerdays
Cycling in the sun
Bristol
Ortlieb for me too! Ok they were expensive but the original panniers I bought (can't remember the make) lasted 18 months and weren't waterproof, and ended up with loads of gaffa tape on. My Ortlieb ones have lasted 5 plus years and are still waterproof.
I have had to repair both mine and my OH's Ortlieb panniers but they took a lot of abuse on our aborted round the world attempt... but I have also noticed that the tour that finished yesterday through Wales and some off-roading has resulting in a couple of pinhole 'tears' where I can see daylight through the bottom - that will be the brambles I cycled through :whistle:... the repair kit is not expensive and it is really easy to do, so no harm done. Even when my OH tried cycling through a bridge rather than over it, I was able to repair the panniers much faster than his bruises healed...:B) I wouldn't mind but he's a physicist and came out with the argument that if you hit something hard enough and often enough (meant to be at a molecular/atomic level or even particle level) you will eventually go through it :wacko: His first attempt did not work! that is all I can say about the matter. Still a few battle scars makes the panniers look used :whistle:
MontyVeda
ortlieb here too... a pair of classic front rollers (used mostly on the back) which are still going strong long after I've forgotten about the expense. Ortlieb offer the sort of quality you only pay for once.
KneesUp
are they not fabric ones? great quality from what I have heard/read about, but not waterproof IIRC
They are supposed to be water repellent - the fibres expand in the wet and therefore close the microscopic gaps. Some claim that a fully waterproof bag like an Ortleib is fine until you put something wet in it, or have to open it in the rain. I have to say I'm tempted (in the 'if I had the spare money' sense) by the Carradice ones with a bin bag around things that it was absolutely essential to keep bone dry.
summerdays
Cycling in the sun
Bristol
I've mended a small hole on mine where it was dragged along a brick building (slight misjudgement on my part). I don't expect it to last forever as I do give mine a lot of use/abuse, but I'd feel I'd had my monies worth if I had to replace them tomorrow. I did replace the handle mechanism recently.
