Salty seadog
Space Cadet...(3rd Class...)
Phew.... stand down people, smoke if you've got 'em.
I've been on tenterhooks awaiting the result....Phew.... stand down people, smoke if you've got 'em.
If I wasn’t so awesome I’d think you might be taking the mickeyI've been on tenterhooks awaiting the result....
Done up like a kipper eh?It's the only way....
I know my plaice.....Done up like a kipper eh?
The only way? You look like you’re doing several different methods of ageing yourself at the same time.It's the only way....
Not so, the smoking and pickling are preservation methods :-)The only way? You look like you’re doing several different methods of ageing yourself at the same time.
Poor old deers....I have some finely aged venison steaks on order for the weekend.
You have identified the solution in your last sentence. You won't be able to get heat into the middle of a steak if it starts at 4 degrees, so half an hour or more out of the fridge is necessary.I like my steak rare (have tried medium and didn't much like it).
Thing is I struggle to get heat into the middle of the steak, warm would be good.
Last two ribeyes were pan fried a minute on each side, I was considering putting it in the oven after for 5 minutes to warm the middle through a bit but I want to avoid cooking it if possible.
Mistake last time was not to bring it up to room temp first, will have to remember that one!.
https://amazingribs.com/more-techni...-science/myth-let-meat-come-room-temp-cookingYou have identified the solution in your last sentence. You won't be able to get heat into the middle of a steak if it starts at 4 degrees, so half an hour or more out of the fridge is necessary.
