which tyres for the wet and slippy routes
bristol-dave
Regular
Bristol
Hi folks, could do with some advice about tyres. Monday morning, hit the gym, left for work 9 1/2 miles away. Went across a flagstonned square, did a very soft right turn , and bang, the back went from under me . I wasn't going at speed cos of all the people toing and froing to work . Just embarressed but unhurt . At present i have specialized all condition 700 x 28 , a mate at work i was chatting to, had a similar incident using sport contacts , his skid was on fallen wet leaves.
So i know find myself riding very carefully, and worried when cycling in the wet over cobbles, wet leaves and flagstones, and at this time of year i cant avoid them on my route.
question is im thinking of getting winter tyres, and i want grip but dont want the tyres too slow me down too much, also should i stick to 28's or should i go upto 32 or more ?
ianrauk
Tattooed Beat Messiah
Rides Ti2
cycling in the wet over cobbles, wet leaves and flagstones?
Not many tyres will give you much grip with those conditions.
It's best that you just take it easy and a little slower.
Wet leaves especially are a nightmare.
palinurus
Velo, boulot, dodo
Watford
I like to use puncture-resistant tyres - Specialized all condition 28s currently, very effective- in the winter when the roads are more likely to be wet, partly because punctures are more frequent when it's wet (for some reason I don't completely understand- perhaps stuff is more likely to adhere to the tyre and get worked in or perhaps the water sort of lubricates the puncture-causing stuff helping it to penetrate the casing, maybe some combination of the two? like I say, I don't know)
Anyway, those sort of tyres tend to be less compliant and hence less grippy. The benefit is worth it though, I just ride slower and take it easy when there's leaf-mush and stuff on the road or other surfaces likely to be slippy.
Flagstones can be terrible when wet too, some of them are pretty shiny.
palinurus
Velo, boulot, dodo
Watford
Running them a little softer can help though. I used to run at 100 pounds all the time. I don't weigh that much, I generally keep about 75-80 in the front and about 80-85 in the rear now.
Andrew_P
In between here and there
My old Tyres (originals fitted to a Roubaix Comp) were great always felt pretty secure, which could have been naivety they lasted 2800 miles relaced them with Spec Roubaix Pro and they are really skittish and I too feel strangely nervey on them. Not sure if they need 500+ running in, even managed to wheelsping them at first pulling away out the saddle in the wet.
I only got them as they are 25 casing and 23 contact, the sides have a bit of tred which I though would be helpful!
So I too will be looking around for something else!
ianrauk
Rides Ti2
This...
