White industries ENO eccentric hub
Sharky
Kent
You could also try a half link chain. About £10. Cheaper than a bb.
Cycleops
Accra, Ghana
Or just a simple chain tensioner a lot cheaper than either :smile:.
rogerzilla
Useless for a fixie.
The ENO hub is a good idea but I found it gradually lost chain tension under load. The more hills on the ride, the quicker it slipped. I even fitted longer bolts (the originals aren't the best) and really mullered them down tight, roughened the ends of the "axle" and fiddled with chain length and hub orientation. Gave up in the end and bought a frame with horizontal dropouts.
alan1
Dorset
sorry the pics are crap, 32 ss/db spokes hub, rim and spokes all new just been hung in my garage as I gave my Daughter the frame that it was intended for.
I suspect postage to be about £10.
If you want more pics just say .
The hub is s/s fixed---free. Regards alan
derrick
derrick
Do you know the width please.
derrick
derrick
If it's 130 can you send me payment details.
Cheers Del.
alan1
Dorset
Yes it's 130. I'm willing to send it for you to try providing you are willing to return it if you're not happy.
Postage would be at cost.
Regards alan
andrew_s
Gloucester
I had no such problem with mine.
I'd guess that the difference may have been that my chain/chainstay lengths were such that the axle was positioned in the lower rear quadrant, relative to the bolts, so that chain tension and weight/pothole impacts worked in opposition to each other.
A half link should allow any bike to use the same quadrant.
