Why commuting gets no easier
Hawk
I've heard this a lot, how does being clipped in actually make you more efficient?
You can pull upwards on half the pedal stroke as well as pushing down. You can also do this with clips.
Clipless shoes are made stiff so less energy is lost in bending your shoe
The shoe fits tightly compared to trainers so less energy is lost in moving your foot around your shoe when pedalling
Clips and straps tend to bend a lot and absorb some energy, metal clips do not.
I think that's the physics of it - might be wrong
Deleted member 20519
Ah, so with normal pedals you can only push down on your pedal stroke but you can double your energy (?) by pulling and pushing. Never thought about that.
I've read this post with interest as a newbie to cycling. I've been wondering about improved times, average speeds etc but about weight loss and less timber around the midriff? I reckon, in the month that I've been riding I have seen my belly tone up though the muffin tops remain and my weight has remained constant. Surely this will improve with time? My commute is just over nine miles each way.
I commute a similar distance. When I started I lost two inches in waist size and gained half a stone. Apparently muscle is heavier than fat. I wasn't overweight when I started, just developing middle aged spread.
Thomk
Thomk
Warwickshire
Is the OP a plodder? If so don't plod. Concentrate on your riding technique so you are as efficient as possible then you will find you can ride 40,50, 60 miles each day without problem, or becoming knackered and do it reasonably quickly with good recovery time. If you haven't got SPDs or cleats then get some as this will grealy increase your pedalling efficiency and the distances you can comfortably ride. Eat properly and perhaps do some cross training. Get plenty of sleep.
No I don't think so what makes you ask?
GrasB
Nr Cambridge
Hu? This doesn't make sense. The point is most people will maintain a given level of perceived effort (PE) when riding a bike. They get fitter & can produce more power so for the same PE so travel faster. Personally I will gravitate to a level of cycling which puts my heart rate at 130-150bpm for multiple <70 mile trips if I've got no reason to regulate my effort level. This is my 'DLOCK', on the PE scale it's moderately hard effort level & I can keep this up for <300 miles/week with mild fatigue levels week in week out as long as I have one rest day. When I have a specific objective in my cycling, say doing a structured training ride or going to a meeting across town, my PE will be different to my DLOCK PE. Before I started training properly this put my nominal ave speed in the 18-20mph range, now this exact same effort level puts me in the 20-23mph speed range.
To keep your foot on a flat pedal (even with toe-clips) you need to keep a fair amount of weight on the pedal, not only does this mean you have to push harder on the down stroke but you're also putting power into resisting the upward motion of the pedal on the upstroke.
Going clipless allows you to completely unload the pedal on the back stroke & if you train properly you get into the habit of pedalling in an egg shape with the peek of the egg being about -45 deg TDC. Once trained you're gain double the power you were putting into resisting the upward motion of the pedal. You can easily be looking at gaining 15% power like this. Also it puts less strain on your joints. Further to this, when you want a big burst of power you can use the upstroke to gain a little more torque (more so at low cadences than high), which is useful for getting over that short steep section of a climb.
lukesdad
A "comute" with significant climbs.http://ridewithgps.com/routes/794174. Try doing that twice a day in a suit Greg. ^_^
redcard
Paisley
All very vague and meaningless advice.
Crankarm
Nr Cambridge
Pretty much the essence of it. Cycling shoes are stiff so do not bend when you are powering around the pedal stroke. Having spds or cleats mean you can keep power constant and not be a like a plodder in knackered trainers which are so soft and not suited to cycling. Push down on one pedal than the other, alternating, so inefficient and tiring.
