Women's Electric Bike
Hi there
One of my female friends (aged 54) would like to get into cycling to get a bit more fit. She's not planning on cycling massive distances or elevation - more likely to cycle along the canal paths and cycle paths and the odd bit of road cycling with manageable hills. I have suggested that she get an electric bike (at least to start with) to see if she likes cycling and how she gets on.
Has anyone any recommendations? I was thinking something that is not too cumbersome so she can take it on and off a train.
Thanks in advance.
Sharky
Kent
If trains are involved, I believe a folder might be more accepted on trains. Non folders may be restricted during peak times.
All uphill
Still rolling along
Somerset
I expect you have told her that an ebike will likely weigh more than a normal bike, and that there may be issues taking it on some trains or leaving it at some stations?
Widnes
I have a Raleigh Motus and have had it for about 5-6 years - just approaching 12,000 miles and had very few problems
Mine has a cross bar but the new ones are all step through
They have Bosch motor system which works well and if reliable
The range is a critical thing - and the current Motus's (Moti??) all have a bigger battery than mine - and mine will easily do 2 -3 20 miles rides along canal paths and the like
As far as trains go - there is clearly teh problem of the rail companies and trains
We have a folder and that would sort that out - it is a carrera Crosscity-e but it is heavy and the range is much less than the Motus
also the battery had "gone" for the second time in spite of not being used much - hence my feeling that Bosch are the most reliable
Dadam
SW Leeds
Something like this might fit the bill. I have no experience with this model, but it looks good. Fits people from 5' to 6'4"
https://www.cyclechat.net/threads/ridgeback-errand.308916/
Taking them on the train only restricted on TfL to electric folding bikes. Other trains only subject to same restrictions on capacity / booking as normal bikes. https://www.nationalrail.co.uk/on-the-train/train-travel-with-bicycles/
But yes an electric folder does give more options
CXRAndy
Lincs
I converted my sisters folding Raleigh bike to an ebike with TSDZ2 motor and rear pannier mounted battery.
Good for 30miles, top speed 15mph, climb 20% gradients with ease on full assist
travellingwest
Not to go against the flow but I turned 60 last year and took up cycling again after an approx 17 yr gap. I bought an off the shelf fairly standard hybrid bike to cycle pretty much the same kind of routes you are suggesting your friend will cycle. To my mind she would be better going to one of the many cycle second hand stores (there's a list of them on the forums somewhere), get herself a hybrid that won't cost the earth to see if she likes cycling. If she does, she can always get a Skarper (or alternative if there is one but that's the only one I know of) to take with her should she find a gradient that needs a bit more oomph than her legs can give. If, somewhere down the line she really gets into cycling on a regular basis, then she could invest in an ebike. But they are quite expensive for a try-it-to-see scenario in my personal opinion.
Widnes
There is a list of bike recycling charities - if you can find the thread then that would be a good place to start
SuperGalactian
I’m late to this thread, but I do have a strong recommendation. We bought my wife a Cannondale Quick 4 hybrid bike, and fitted it with an electric conversion kit from Cytronex. I had done my research, and already tried out a Cytronex converted road bike, which was hugely impressive. My wife absolutely loves the bike. It allows her to climb hills that were previously unthinkable, commute to work regularly, and accompany me on day rides. When she has the power on full I cannot keep up. The Cytronex system isn’t cheap, but it is brilliantly thought through, uk road-legal, and works immaculately. You can have it fitted (for a fee), buy an already-converted bike, or fit it yourself. The latter is within the ability of anyone reasonably handy, and the instructions are anally detailed! I have no affiliation with the company, I just want to applaud a really good product. I’m 71 tomorrow, and when the time comes to admit defeat I will get a Cytronex kit too.
EDIT:
PS - the battery goes in plac of one of your bottle holders, and can be simply removed and taken with you when you leave the bike. The motor is in the hub of the front wheel, which replaces the original wheel.
