Ibby22 said:
I am wanting to spend about £700-£1000 on a road bike. Have looked at a Cannondale, Specialized and Scott. Have had mixed responses from shops re panniers. One said couldn't have them, 3 said I could
Any advice would be gratefully received. Must be a road bike which can fit 2 small side panniers, ideally could you tell me how and
what I would put on frame to attach them.
Thanks
Ibby
A pannier rack. Simple as that.
Fitting the rack may not be completely straightforward - it will depend on whether the bike you choose has the necessary bolt-holes (bosses) as part of the frame. If it doesn't, you need to look into using something like P-clips. Any decent cycle bodger will be able to work a way round it. My Giant FCR (a flat barred compact road frame) had a single boss at the rear hub for a mudguard, so the rack doubles up on those bolts at the bottom, and the upper fittings are attached to the seatpost clamp bolt.
A rack that is attached this way may not be able to carry huge wieghts - although my FCR has coped with camping kit for a weekend, and plenty of shopping day to day. But if you only want small panniers, I don't see a problem. Anyway, if you're set on a road bike, and lightness, you'll want to fit a light rack, so that will perhaps limit the weight you carry.
If you had very big feet, you might find your heels clipped the panniers - although fitting them as far back as possible normally solves that.
Maybe it's because I know the right sort of people (enginneers, lifelong cyclists etc), but I've never seen a problem that can't be worked out.
