WTD: bits for fixie project please :)
iLB
Hello there
LONDON
i need some bits for a fixed conversion i'm thinking of doing, any help much appreciated
i need either a 700c or 27" rear fixed wheel, and a crank set and a chain please...
here's the bike i'm converting, so far i have cleaned it all up and got it in working condition
i could also use a 27" tyre (the bead is damaged on the one in the photo, so i am running a 700c wheel on the front atm) and if anyone knows where i can get hoods to go on the brake levers (shimano 600 i think, the same as the rest of the groupo)
... and thanks alot to aperitif for the kind donation of the original bike :eek:
dan_bo
How much does it cost to Oldham?
ooooh a proper falcon!
Joe24
Nottingham
Just wack a fixed sprocket on, it probably takes a screw on block so you can just put a fixed sprocket on tight.
It shoudlnt come off.
I did have a chain, but ive ended up cutting it up to use as abit on a chain whip.
If you need some 1/8th chain to make up a chainwhip then tell me.
