WTF?
RiflemanSmith
London UK
I just had my bike serviced as I had a problem with the gears, it is only 3 months old.
I got it back and they had changed the gear cable gears are better but still not good.
I am not so fussed about that but I don't understand is why it is harder to pedal now?
It feels like I have gained another chainring or like I had only been using the second one and now I am using the third?
I've never taken it out of the third one so I don't know what's going on?
What could make it feel like this?
ianrauk
Tattooed Beat Messiah
Rides Ti2
brake blocks rubbing?
defy-one
Cable could be too tight. Can you engage all your gears and all 3 front rings.
I would go back and show them
RiflemanSmith
RiflemanSmith
London UK
Yep nothing rubbing, wheels turn freely tires pressures are correct?
Yep gears all change just not precise with one click like they should be.
compo
Harlow
Do you know what "crap" they used on your chain?
I recently tried chainsaw oil, after reading about it on here, and it was like pedalling through treacle. I removed and cleaned the chain then relubed with normal oil. Once refitted it all felt better. Cycleogical? Maybe, and I am not going to enter into a debate about chainsaw oil or chain lubes!
RiflemanSmith
RiflemanSmith
London UK
I don't know what is was but there was way to much on as the excess hadn't been wiped off.
It is really shiny and tacky to the touch.
RiflemanSmith
RiflemanSmith
London UK
I haven't got any brake cleaner, will white spirits be any good for cleaning the chain?
Just use your existing oil, apply to chain and wipe off. The sticky lube is likely to be a heavy duty one. It's wont make the bike slower.
If the wheels and cranks spin, it's probably your legs.... LOL
