If however you want to run one front chainring, or run it as a double and bash, then my personal recommendation would be a 34T or 36T Deore, depending on his legs. You can get fancy Middleburn or Blackspire aftermarket middle rings, and if you don't mind paying for that quality, then they would be the way to go. There are various types, depending on whether you want ramped and pinned for a double setup, or plain for a single front chainring. If you're going for single, bear in mind the extra cost of a chain retention device.
XT is 104 BCD 4-bolt, so check that that all fits before you buy. If you're simply losing the big ring then you could stick with the 32 that's already on it and simply add a bashguard in place of the 44t.
