dan_bo
How much does it cost to Oldham?
Werd.And I don't mind any instant gravy so long as it doesn't taste like coffee.
Are you sure you're using the correct jar from the cupboard danbo?Ill drink any coffee as long as it doesn't taste like bisto.
By that argument, all restaurants should be avoided. After all, cooking is a rather simple task also.Why is it that most people have seemed to un-learn the rather simple task of sticking some ground coffee into some hot water (or milk) and then pouring it into a cup and instead stand there while some ponce does it for you and then give him £2.50?
Double checked.Are you sure you're using the correct jar from the cupboard danbo?
Unfortunately its not an option at work , cheap, strong black is as good as it gets .INSTANT coffee!!!!!!
Cafetiere ... simples. Put whatever ground coffee takes yer fancy in it.
Life really is too short to drink INSTANT coffee.
Did you know that Cafetiere is a brand name. The thing you use for making coffee is a French Press. I got told off, quite loudly, about this in a posh cafe and thought that I would pass the knowledge on in case anyone here goes into the same cafe and comes across the same snotty bloke with a loud voice designed to belittle anyone who dares ask for a cafetiere instead of a French Press.INSTANT coffee!!!!!!
I find this hard to believe. A théière is just a teapot. A cafétière is just a coffee pot. With a plunger, apparently, it's a cafétière à piston, which I have yet to hear used in France.Did you know that Cafetiere is a brand name. The thing you use for making coffee is a French Press. I got told off, quite loudly, about this in a posh cafe and thought that I would pass the knowledge on in case anyone here goes into the same cafe and comes across the same snotty bloke with a loud voice designed to belittle anyone who dares ask for a cafetiere instead of a French Press.
I am willing to bet that gobby chap has a 'Hoover' (and and someone to wield it) though. Probably wore Roller Blades when he was younger too.
Instant coffee may as well be piston.I find this hard to believe. A théière is just a teapot. A cafétière is just a coffee pot. With a plunger, apparently, it's a cafétière à piston, which I have yet to hear used in France.
So I was spoken loudly to, and belittled by a right arse who knew nothing. Heigh ho.I find this hard to believe. A théière is just a teapot. A cafétière is just a coffee pot. With a plunger, apparently, it's a cafétière à piston, which I have yet to hear used in France.
