Charge Plug 3 Special Edition 2013
russ.will
russ.will
Slimboy Fat
The Fen Edge
Yes, it's okay, but even if there is lighter, the compliant ride of the steel frame makes up for it. To be fair, with mudguards, lights and the amount of rubbish I pack in a ruck sack, a kilo here or there is a non-issue.
simon.r
Person
Nottingham
I don't think they're wide enough for a 38mm tyre. I've not used that specific brand but have some of these: http://www.wiggle.co.uk/sks-race-blade-xl-clip-on-mudguard-set/ They're the wide version and will just fit a 32mm tyre. I don't think the Crud Roadracer is any wider than the SKS Race Blade.
GrumpyGregry
Here for rides.
It's a Plug. It doesn't have a compliant steel frame! ;)
  • Like
Reactions: gaz
Emile2
Hi - I have the same bike, and having just had to fix a rear puncture, I'm now paranoid that I put the nuts on the rear axle incorrectly - you don't have a close up image of them to help me out do you? Especially on the side underneath the gear wire.
