nickyboy
Norven Mankey
- You want hills? We got hills
[QUOTE 4150574, member: 9609"]but this is the bit I can't get my head around.
if it would take 50kgf to push vehicle from rear or the same to push the socket bar at the same diameter as the wheel. Then if that wheel was 1.5m radius then the torque would be 1.5x50= 75kg metres
if the wheel had a 4 metre diameter then the torque created at the nut would be 100 kg metres
I think there is something obvious i am missing here ?[/QUOTE]
You're comparing apples with oranges.
Force applied is measured in Newtons (or Kg x g if you prefer)
Torque applied is measured in Newton metres (or Kg x g x m if you prefer)
Torque is not the same as Force
