Piemaster
- UK City of Culture
As I've already started, why it's easier to move the tractor using the wheel than just pushing it, it's an increase in the length of the lever. You could of course just eat more spinach.
Please expand?I agree with Descartes on this question. We simply can't know.
Ah. The separation of body and mind?everything can be doubted except my mind?No. I'm large enough as it is.....
(Descartes said we can't know anything because we can't trust our own senses.....all of this might be a dream or a wicked plot by someone trying to fool us)
If it is a dream it's a very persistent one. (I think that was Einstein - but I might have dreamt that)all of this might be a dream
I suspect that you may be confusing torque and force. The force will vary inversely to the length of the lever although the torque will be the same for any given radius of wheel. In cycling terms, for any given speed, you have to push the pedals harder in a high gear than in a low gear.No matter how you look at the problem - from a torque to the hub idea or a linear push from the rear idea, the amount of force required to get the tractor to start moving is 500N (rounded up for sanity). Now, see the tractor as positioned about 1m from a wall and you are between the tractor and the wall. Your feet are up on the wall and you are pushing the tractor back at 500N and it starts moving. Now, put a lever of unknown length on the hub and again position yourself against the wall. How hard do you think you have to push on the lever to get the tractor moving? I'll give you a hint. The opposing force is 500N.
Reality is merely an illusion, although a very persistent one - Albert EinsteinIf it is a dream it's a very persistent one. (I think that was Einstein - but I might have dreamt that)
I'm afraid it can't.
Kg is a measure of Mass. So if you're on Earth, Jupiter, wherever...a Kg is a Kg
But force varies dependent on where you are. The Force required to lift a Kg on Jupiter is not the same as on Earth. As it does to accelerate a body
I offer an online course in MS Paint. See my previous posts for the quality of work you can expect to achieve after only a few lessons. My rates are very reasonable.I was hoping it wouldn't come to it but I can see I'm going to have to break out MS Paint to do a diagram.
Ahh, you fall into the trap that many people do. You have made your Paint effort look good using shapes and stuff. For authentic results everything in Paint should be done freehand. Using a mouse.I offer an online course in MS Paint. See my previous posts for the quality of work you can expect to achieve after only a few lessons. My rates are very reasonable.
