mybike
Grumblin at Garmin on the Granny Gear
- Not 'emel 'empstead
[QUOTE 3658137, member: 45"]Try reading the opinions, arguments and the limited modelling and research available to google, and the valid points put across on here, and then have a think about what you're saying.[/QUOTE]
I do.
[QUOTE 3658137, member: 45"]The queue is half as long over two lanes than just one. All other things being equal, this doesn't reduce the length of time to get through. But, as said before, shorter queues are less likely to block junctions. And if drivers merge towards the front this removes the "polite" drivers getting wound up at being passed and doing stupid things which do slow the traffic.[/QUOTE]
The queue is exactly the same length, but spread over two lanes. That means that there are two lanes blocked instead of one and there is extra delay caused by drivers changing lanes.
[QUOTE 3658137, member: 45"]As always, people are focusing on what others should do rather than what they should themselves. See my sig line.[/QUOTE]
Not at all, not that I think the HC is that good a document. I think those who don't think enough have too much input to it.
I do.
