Carwash said:I don't think you understand the concept of 'screen resolution'.
well please feel free to enlighten us
peanut said:well please feel free to enlighten us
Carwash said:By all means. What I was getting at is that if you have trouble reading text on screen because it is too small, reducing your screen resolution is not the right way to remedy the situation. Increasing the text size is. TFT monitors have a native resolution, and setting them to anything other than this will make your display look like a dog's breakfast, and sacrifices the space available on your desktop in the process. Increasing the text size will keep the text sharp; reducing the screen resolution will... well, reduce its resolution!
(Of course it's not just a question of the pixel dimensions of your display, but also the pixel density: 1920x1200 pixels on a 17" screen will be sharper - but smaller - than the same number of pixels on a 32" screen. As always, these things become more complicated the more you look into them!)
peanut said:Thanks for that explanation however the whole point of this thread is that if web designers utilize more of the screen for their webpages then regardless what screen size or resolution your screen may be set at the text will be proportionally larger without adjusting anything.
peanut said:I spend at least 12 hours most days at the computer and this stupid minute text is really causing problems for my eyes.
Admin said:The 800 x 600 design restrictions are historically very simple - that was the default Windows desktop resolution for a new install / PC.
That's why designers traditionally used those boundaries.
Things are different now with widescreen PC's and laptops, etc. but a new PC is still somewhat likely to have the default 800 x 600 desktop size.
If you want to use the full screen width on CC, simply select 100% Width from the drop-down at the bottom left of the forum page. Alternatively there are several other width settings so you can chose your own preference.
If you want to zoom in or out of any web page in IE, just use CTRL+ and CTRL-, or depending on how the site HTML / CSS is constructed you can increase just the text size using View > Text Size and selecting one of the options.
Hope this helps.
Cheers,
Shaun :?:
punkypossum said:Mine's not on the list: 1280x1024
Carwash said:There's no denying that web designers in general could certainly do a much better job of making their sites accessible to users with, for example, visual impairments. But users themselves are empowered to display sites as they see fit - the tools are there, why not use them?
